Sign in to follow this
PeteB
Ford Focus Won't Start!
Not really gone into it - trying to get something else going but this bugs me....I drove it into place back end of last summer, changed the clutch (after starting it) and now the bugger won't go! Any quick tips?
Share this post
Link to post
Try jump starting it, if that don't work chances are your battery has failed a cell or two , the computer etc wont allow the engine to fire unless the battery is 100%.
Share this post
Link to post
Engine derv or petrol ? dual mass flywheel ?
Share this post
Link to post
Pete, have you connected the crank sensor back up after changing the clutch i know transits have them so the focus might have them too?
Share this post
Link to post
If none of the above works a lighted match should get it going...
Share this post
Link to post
Think the missus might suspect me of this!
Old style sprung clutch, never touched the flywheel, petrol, reconnected everything and it did start and run once! Now just turns over - the gas in the tank is a year old mind!
Share this post
Link to post
I have a car on my drive that had petrol in 08 still starts first time over so petrol is a really long shot. Take the plugs out and clean them, check you have a spark, check you have petrol getting through. Presumably you have an electric pump so carefully crack the line or perhaps the plugs are wet.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
