I'm thinking of the 40 inch for wide hedge tops.
I struggle with the long reach cutters weight wise if I'm honest when hold horizontal.
So I'm thinking 40 inch plus my reach will deal with most tops.
I've only git 3 hedges that would need the t version I think and I can use what I have for those.
Would the r be ok for tops you don't really see?
I bought long reach hl95 in the last year and wish i didn't because of the weight. Too heavy for a proper session. Also underpowered once you have used the 82 + versions. Unfair to compare them but you do.
It really depends on what you want to achieve. I have used lots of hedge trimmers, which generally are of the 'T' version principle - lots of teeth and a fast speed. I tried out the R as I was dealing with small branches 10-20mm more than your traditional hedge size. The R has noticably less and more spaced out teeth and the speed is considerably slower. I find it chews through overgrown material rather than cuts. It can achieve a level finish but the hedge will have a 'flail' look to it.
Ive used the stihl hs86r,theyre ok for most jobs.They
WONT give you a nice crisp finish on a conifer hedge though
Agreed. The Stihl or good for cutting rough hedges but won't trim a Conifer nicely after its fourth day out!
An Echo will still be cutting conifer nicely after three years.
  • 1 month later...
im going to disagree here, i cut this yew hedge every year with double sided 81 r's
Still can't beat the old robin hedge cutters for cut quality. These are now sold as dolmar/makita and will be my next purchase. I just actually out my old robin in for service and repair, hoping to get a little more life out of it as I do very little hedge cutting these days
+1
I have the Makita HTR7610 (formerly Robin) now 16 years old and they have been faultless.
Same, done these monster hedges and a few more like them with a single sided sthil with a catcher plate for 3 years now and still cuts as good now as day out the box
Sent from my D5803 using Arbtalk mobile app
Looking good mate:thumbup1:
