Hand pole saw choice?
Plwm
Hi folks, I'm looking to buy a long pole saw, circa 6m, for occasional personal use in my small wood and would appreciate the opinions of those who've used the various brands / designs.
My shortlist is -
Stallion 6.3m @ £126
Stein Pole kit 4 + 1.8m pole + 1.2m pole @ £169
Jameson 1.8m base pole + 2x 2.4m sections + head+saw @ £172
(Prices approx)
At long lengths is it better to use a sectional pole design rather than the extending type with regards to flex/control/efficiency of cutting? The Stein and Jameson seem very similar products? I know Silky have a great reputation but my budget doesn't stretch to those!
Would I be able to fit Silky saws to the above in the future if I wanted to?
Thanks in advance...
I would take the 4.9 m silky for £190 and use steps ! Seriously I would regret using any thing other than the silky , the stein and Jameson do not compare( unless your pulling out hangers) I've owned both, can't comment on the stallion though, it seems value for money....
Thanks for the swift replies guys! I've always had the ethos of paying a bit more than I originally plan to get something that'll be better quality in the end... a quick google and the Hayauchi 4.9m can be got for £175 which puts it in my price bracket... :-)
I have the stallion 6m. It is effective and the head is supposed to be interchangeable with a silky blade, I've not use a silky. At 6 metres it is a bit like a pole vault pole for flexing, you certainly don't want to be operating these lengths for a long period, I swop and change.
Mine is handy I find for doing branches that are overhanging 2 storey houses at the gutter height. The longer reach are stiffer at shorter lengths as well I believe.
Used to usea Silky Hayuachi, until it got nicked. Excellent, as was the Sintung lopper head. Couldn't afford a second one, so bought the Stein set-up. All good, in fact the Stein lopper was perhaps even better, bnut the blade is poor in comparison. It is possible to buy an adaptor though , to allow a silky blade to be attached to the Stein/Jameson poles, (which are identical, by the way) Hope this helps.
