Show your tractors
Will Cobb
Got my new purchase (the International) back from local Mr Fixit - new oil in rear axle, new hydraulic filter, new fuel filters, new air filter (one we took out had an International Harvester label so was probably original!!), new seals on fuel pump, new seals on PAS, second hand drop arm on 3 point linkage fitted, wheel bearings tightened up, stop cable fitted.
Winch put on and now in the woods to assist with felling. Engine is sounding better all the time now it's actually working for a living, think it must have stood idle for a long time.
Hi rover what international that then mate is it the one with Perkins engine thanks Jon
Wilsons said maybe a little big on n92?
It's a 92 i thought it was a 101. Yea that extra weight and reach will make it a little top tippy. It will still change the way you do everything though you will be very impressed with it. The small size means you'll get into lots of places too.
Have small 4 cyl tractor with roof mount now. Don't won't any thing to big
