  • Replies 32
I've put a couple of louvres in my ms150 exhaust, I used a dremel cut off wheel and screw driver/flat pliers to open up the vents
Did you have to adjust the carb it's 3 weeks old so do you recommend now or wait for the warranty to run out thanks
If it's done a couple of hours work it would be a good time to do it, you may have to richen up on the H screw 1/8 to 1/4 turn, (anti clockwise).
[ame]https://vimeo.com/171219135[/ame]
Hi giys don the mod how does it sound haven't touched the carb settings yet seems to cut good trying to upload but Taptalk says the video is to big only a 1 minutes long please advise welcome as don't want to damage piston ect it's only a 3 weeks old [emoji4]
It seems ther is a stop on the h screw as can turn clock wise but not anti clockwise so i can go no furthe than it could before?
Sent from my D5803 using Tapatalk
Edited by Pbtaylor2014
Pull the plug out after a running the saw for a few cuts in the log. Have a look at the colour. Do the same again and check the colour and adjust accordingly.
Just don't pull the cap too hard as I pulled mine off!
