MS261 query
Taupotreeman
If you put a location in your profile, it doesn't need to be your address just a city or even a county then someone may be able to help with something a bit more specific. Our local supplier Spire bearings is really helpful and will get most things in a couple of days. He did pull me up when I asked for metal caged bearings for one job saying that the fibre cage option they supply actually runs cooler and holds lubricant better than a metal caged alternative and the rollers do the work not the cage.
  • Replies 35
Thanks for reply Mark. I have been looking for metal cage bearings as well but all the sellers at the moment seem to be selling plastic ones. I would appreciate a heads up from anyone finding metal caged bearings.
Have bought metal caged bearings from garden and hire spares if that helps...."Other part dealers are available " :biggrin:
If your issues is that your crankshaft is worn from excessive clutch drum wear. This also trashes needle bearing and oiler arms. Also makes the saws run like a pig and stall when you put the chain brake on.
This is now a warranty repair job, or at least here it is.
I have just ordered from garden spares :thumbup1:
I don't have any problems with bearings or crankshaft ( my saw is 2015) but just want to take precautionary measures just in case.
Thanks for all replies.
Is it not the end of the crank that has been ground slightly oval causing the bearing to eventually fail ?
I don't know if it is, but this thread is the first time I have read about that theory - and I will only believe it when evidence is presented.
If that proves to be a fact, the issue would be more serious than I have been thinking....
I read it somewhere a while back . Think it was on this forum about the time it all started kicking off .
