TOday i went out with a mate to rec climb just to practice SRT - Now im rather new to SRT especially for moving around the canopy - I found myself climbing the tree a lot more like i would free climbing this meant that at certain moments - usually the most tricky there would be some slack in the line as a climbed up or back in from a limb walk - not much but still enough to make me think if i fall on this its going to put a lot of force on both my back and my anchor point - and this got me wondering if any one has ever installed some kind of shock absorber into their srt system?
A snake anchor particularly as a base anchor would take a lot before it started to absorb maybe as much as 10kn so you going to have issues.
I've not yet seen a decent shock absorber yet, just use a line with a bit of give and keep slack minimal, or when you do have slack be sensible and not push your luck.
I have seen a system like that. It consisted of a lanyard with two ends and shock absorbers. V shaped with bungee shocks.
I used to have one for climbing via ferrrata in the Dolomites.
VIA FERRATA EDELRID SET - | Decathlon
It is really intended for horizontal climbs where if you come off and you are clipped to the fixed wire that is there on a via ferrata the shock is absorbed. It could be incorporated into a base anchor.
There's a nother way to do it involving a slip-friction device on the climbing line. If I find a picture I will post it.
When using work-positioning techniques, do not climb more than 250mm above your anchor point. Keep the climbing rope taut. Ensure any slack does not exceed 500mm.
AFAG401
AFAG401
Meanwhile in the real world :001_tt2:
I agree with you but in practice it does not always happen.
Only this weekend I was up a large Horse chestnut reducing the top must of been 1m above my anchor on skinny stuff, so 2 m fall, I was lanyarded in but that's not a life line, it was the safest option I had at the time to achieve the job efficiently.
Or there's this
https://www.totalaccessonline.co.uk/Products/Lanyards/Fall-Arrest/2-5m-Retractable-energy-absorbing-lanyard
Bumble B just quoted AFAG, quite right. It's probably best not to rely on a device that is needed to cover for bad practice. When retreating from a branch walk, it is virtually always possible to anchor from the branch with a second rope DdRT till the danger of a pendulum is passed.
I had a nasty one last week, 14m long Beech limb rising at 45 degrees, nothing on it to hold onto for the first 8 metres, and covered in moss. I went up it a cheval, puxshing in front of me a wirecore lanyard wrapped twice around the stem and clipped to side Ds. There's always a way.
Meant to add, most of these fall arrest lanyards that might be incorporated into a SRT are only rated to static loads of 140kg (0.14kN), and would probably therefore be a fraction of the load rating of climbing ropes (typically 30kN) and krabs (30kN). Why ruin the whole system with a weak link?
