Hello y'all
Β
Now the warmer and dare I say consistently hotter weather is with us I'm thinking it would be nice to have a summer helmet to stop my head boiling like an egg inside my non-vented Husqvarna groundie helmet.
Β
I don't climb so don't need chin straps.
Β
Any suggestions?
cheers, steve
  • Replies 24
Popular Days
Hello y'all
Β
Β
Β
Any suggestions?
cheers, steve
Β
Just drill out the depressions in each side of the ridge . About a 4mm drill . I think it meant to be but the side cores in the mould tool don't quite shut off leaving a flash .
Β
I thought about doing that but then I'd get drips on my head when it chucks it down with rain.
Cheers, steve
Cheers, steve
Β
If you are not wet you are not working ...........Do it to all of mine . :001_smile:
Β
That's very true. Good analogy. :thumbup:
cheers, steve
Β
Or for better ventilation drill 40mm holes all over and the air will stream through!
Β
However, I'd buy a Protos helmet.
Β
Β
Cor, they look good and mighty expensive. A 40mm drill bit shouldn't break the bank... :laugh1:
cheers, steve
Β
Β
If you do that it could compromise the integrity of the lid . You get a 4inch dia stick hit you on the sweed you want it to bounce off not cave your lid in !
Β
I think he was taking the fish with 40mm. Either that or missed a decimal point.... 4.0mm :laugh1:
cheers, steve
Β
As one of our lads found out a while back Stubbs. Al was only joking about the holes :)
Β
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
