Any tips for my cs39?
Joe
  • Replies 35
If Bob is your Uncle, just ask him to asses you!!!:thumbup:
I'm sure he'll go easy on his Nephew :thumbup1:
supprising how big my family is:thumbup:
drop starting in the tree should be done with the hand and arm that holds the saw staying still
so basically same as hetween the knees but held at the end of your arm and not between your knees or half a drop start if that makes sense
27 To hold the saw for a cold start, place the saw on the ground with
the left hand on the front handle and right knee on the rear of the
control handle. Apply the chain brake. Engage the starter mechanism
and pull the starter cord firmly with the right hand. Release the half
throttle mechanism as soon as the saw has started.
28 If conditions prevent a ground start, the saw can be started
using the thigh start, but beware of excess heat if the saw has a
side exhaust outlet. Alternatively, the saw can be started with the
right hand on the control handle. Apply the chain brake, engage the
starter mechanism and pull the starter cord firmly with the left hand.
29 Before restarting in the tree, make sure the saw chain is clear
of obstructions such as climbing equipment, protective clothing or
parts of the tree. Apply the chain brake. Start the saw either:
by holding the front handle with the left hand and pulling the
starter cord with the right hand; or
by holding the saw with the right hand on the control handle
and pulling the starter cord with the left hand.
Using
the
saw
