What are people using to seal end grain.
I've some paraffin wax but it's white. I'd rather something clear.
What do you all recommend?
Do you need to seal the end grain if it's drying outside or is that just for kiln ?
It's always best to seal and protect yourself not going to hurt, all types of wood dry differently but it's easy to seal and can save waste I seal the log then mill easyer then sealing each border afterwords.
I use watered down pva glue. If I cant do it the same day, I tend to trim the board to straighten up the end a bit and then apply it with a brush. Due to the fact the newly exposed surface it wet, the pva soaks in a bit and wont fall off, which sometimes happens with candle wax.
I wouldn't worry about it. Don't know of any larger scale mills that do it and I don't either. We cut over 600 elm boards in the past 3 days - would be quite an undertaking to seal them all!
Do you get any issue with splitting? Got some cherry that's split like hell.
A bit here and there, but it's likely to do it anyway. You can have a much bigger effect milling early in winter, stacking correctly (sticks near the ends of boards, large, tall stacks to keep boards as flat as possible) and picking decent logs.
As a rule, I don't cut cherry any more. Horrible, twisty, bendy, splitty wood. Not worth the effort.
