Anyone else got one?
Just turned up in the post today and seems the thimbles are too small for my rope - blue tongue.
Have to really squeeze the splice to get it through and then the unique id tag won't go through. Even without the id I can't see how it would be possible to install from the ground!
Seems a ridiculous design.
I've got one , 11.7mm poison ivy goes through great . The plastic collar on that rope looks excessive ? Great combination if you don't want complete frictionless like me ..
Just had to google what it was as i haven't heard of it....and found this note on treestuffs website
Important Note: the fimblCLIMB was designed for use with a SLAICED termination. Normal spliced or sewn terminations will have a difficult time fitting through the thimbles on the fimblCLIMB.
Also used on the new pulleysavers as the retreival eye which I have just bought. You can get the blue tongue splice through but the ID cover is a struggle, positive is dont need to use a reteival ball
I cut my ID/shrink wrap off and have kept a copy of the receipt which has the unique product number. Using 11.7 hedera which is basically same rope as blue tongue. Bought a teufelberger rope now though with a slaice!!!
Thanks Steve. Would have been good for me to do the same before buying, but doesn't say anything about it on the FR Jones website, just assumed it would be fine.
What do think of the slaice? Looks good but pricey?
Was getting fed up with the bounce on my hedera and was prob due a new rope anyway so bought some New England tachyon. It's 11.5mm coupled with my pulley saver and zigzag it's a great setup.
Can you install from ground? And yes same as you...didn't want the pulley saver so thought this would be the answer. So do you have the FimblClimb or FimbleSaver?
