Bout the same size. The way I see it if you're using a top anchor SRT the forces are the same as with a cambium saver ddrt.
The exception being side loading with redirects, but then I use static or dynamic redirects depending on the situation.
As I understand it. Dynamic = rope running straight through the redirect krab. Able to move as the anchor stem and the redirect stem get pulled together as you load them.
Static is girth hitching (or equiv.) your line to the redirect crab, putting more weight on your redirect but preventing side loading your anchor.
You can tension up a static redirect with a girth hitch which works well on skinny stuff.
As Joe said.
Skinny mini stuff I either alpine butterfly it or girth hitch it and tension it up so it doesn't move too much.
For me that is the beauty of SRT, almost infinite options for anchoring. Sometimes I anchor into fatter stuff then pass the system through a higher point for better angles. In theory if the top one goes it is backed up below.
