So I've started building my self an Oak dining table in the workshop. I brought a few off cuts into the house that I made into candle holders and they have split within a few days.
A lot of the timber I'm using fell over in the 87 hurricane so ild thought it would be dry, how can I go about not letting it split?
Sent using Arbtalk Mobile App
Colwood Land Care, Tree surgery, Sussex
  • Replies 22
I to have this with well seasond wood especially Oak.I now clamp it and use ratchet straps and leave it inside for a few weeks.Sometimes I'll bring it inside checking daily and if i see the start of a split I'll stick in a bow tie quick.
Kev
I sometimes seal the ends with pva but i do that as soon as i've milled and still clamp and use straps and store in the coolest room in the house for a few weeks then into a slightly warmer room.I'll do this when near the end of build then finish off back in the heated workshop as keep moving from house to a workshop can draw in moisture again.
Oak ideally needs to be stored correctly for about a inch per year thickness. Then kilning to bring the MC down in a slow manner.bringing any month old green wood in the house as you have found will move a food degree.
if you only planked it a month ago, it'll still be green in the centre, doesnt matter how long its been lying, unless the fibres are exposed it wont give up its moisture
