Been getting Alot of jobs that have consisted of a lot of dragging etc recently and decided it is now justifiable to get the arbortrolley the rc4501 version to be precise and the carry bag rcp 4007 your thoughts on them would be greatly appreciated
Cheers
Jayy
Wouldn't be without mine!
We were shifting pine brash out of a garden today and each trip with the trolley was about 8 trips by hand worth. Timber we had 3 bits on which were 2 man lifts to load and unload but saved a lot of cutting up.
On the rite job with the rite attitude it's a real winner and time/effort saver even if it's just carrying all the rigging gear onto site.
Not sure about the bag as use a 4ft x 4ft bit of stock board shoved into the pins to pile rakings or ringed up timber into as it's almost indestructible.
Get it you won't regret it!
Get it you won't regret it![/quote
Thanks appreciate the advice all ordered
Cheers
Jayy :thumbup1:
There have been many threads about the Arb Trolly on this site and probably hundreds of replies. The quality of the product is very good and the solid rubber tyres were a vast improvement over the original wheels. Although I do not own an AT I would recommend one at any time simply because it makes sense and working harder is truly over rated.
easy-lift guy
ImageUploadedByArbtalk1453966887.834330.jpg.4bd8b4ab9134021cef23602626ca080d.jpgthis is ours from the other day we took 10 of these loads out to the truck we had to walk about 40 meters with it, it took about 2 hours imagine if it was by hand!!
An amazing bit of kit, it's heavy but it needs to be, saves a lot of back ache.
