Has anyone fitted van style deadlocks on their defender? Inset ones, not sticky out hasp and staple type things.if you have what do you think of them and where did you get them from, thanks, William.
We have additional locks on my wife's VW T4 although no keys to use them unfortunately as they were on the van when we got it, will have a look in the morning and see if I can find the make of them
Not sure if they may be a little deep for a defender door though although they may be ok fitted low down I think when I measured them before I was after fitting them in the door tops to stop lowlife scum prising the tops down to break in
Hi William I've seen them in land Rover magazines but the only trouble is he still bend the top of the door in a row to get in so waste of time really thanks John
something like this.
Nearside Door Deadlock 040
yes you can break glass or remove it but you still cant open the door, cant be removed from inside, door has to be opened. sort the hinges as well.
plus it devalues the doors because of locks easy to recognise and leave a hole if removed.
plus scum don't know if you have used the dead locks.
not cheap worth thinking about.
needenginerunnin
needenginerunnin
That's the sort of thing, just need to find some that fit an 08 model.
I only have the front windows and windscreen and short of riot grills there's not much I can do about them!
I have seen them fitted about half way up the window frame which must go someway to stopping the door getting wrenched open?
At last years Doe show there was a company selling them(for vans), hopefully he will be there again this year.
Hi William get a pedal lock mate there good all so you can get new hand brake lock to too mate thanks Jon
