  • 2 months later...
  • Replies 64
Alreet, Managed to get the guts out of the muffler and get it all back together, and back on! I want to adjust the carb, but cant even see which type of tool I need to do it.... does anyone know where I can get hold of one?
Your saw has "likely" got limiter cap/caps over the L &H jet screws depending on its age. The red one is the H and the white..if there ..is one is the L jet. A flat small screwdriver is the tool and as long as you can retune within the range of movement you won't need to pull the limiter caps.
Edited by Sawchip
If they had been selling that saw, at that price back in June - id have snapped it up, instead of my buying my 6401.... for £10 less :cursing:
We have had a few of these saws and the newer model is still an animal excellent saws they definitely give the others a run for their money
I did a repair and light port on a DCS7901 recently. The saw had fast pickup but never got the time to use it but the build looked pretty good to me. The circlip tang had come off and caused a bit of naughtiness in the cylinder but was able to repair it as one does.
The low screw on this saw was adjustable but the H screw was blanked by a plug in the side recoil cover. I just tached the saw, removed the cover, gave the H screw a wiggle and returned the cover and got it to around 13000rpm. I think the max is 13500 and the coil is limited so watch out for that!
Haven't got any feedback on the saw yet!
yeah, the saw revs noticeably higher than before, so definitely want to richen it up a bit. managed to get the cover off and have a look, the H screw definitely doesnt want to be tampered with! Ill upload a pic in a sec
Here you go. Looks splined but was quite hard to see. Jammed a screw driver down the side of it but couldn't get enough purchase to turn it. Stopped before I broke it.. Rare occasion
