Hi all
Bit of a long shot perhaps, but I'm looking for 4 pieces of wood to make replacement legs for a garden table. I'd like something that will last, so sweet chestnut, larch, western red cedar? Or other suggestions? (The bottom of the legs will be in contact with cement / earth / leaves, which is often wet). I need pieces about 12-15cm diameter (at the thick end), and 1m ish long. Unseasoned would do I think.
Any thoughts or options, or can anyone supply suitable wood? Including prices? Not a huge amount of budget I fear as the rest of the table is not in great shape, but would be good to keep it going a bit longer if possible. I'm in Bristol.
Many thanks.
Steve's interesting chart throws up another option - if you can get hold of a proper railway sleeper a lot of the new ones are jarrah (pinkish/orange colour), which is also on the highly durable list. If you ripped one down the middle and then cross-cut you would have four decent legs.
Alec
Thanks Steve, and for the useful durability chart. I'm guessing that a single table leg would use between 1 and 2 ft3 of wood? If so, makore is out of my budget by quite a way - cheers though.
Will see if I can get hold of a sleeper (thanks Alec, hadn't thought of that) cheaper! Having looked at the table again, tbink the top might be past it anyway...
Interesting chart steve but I think the times are a little conservative. Maybe Call hazard class 5 examples or something. I always believed that Robinia is called class 1 durable too?
Read more
