Yeah its not great at all. Saw clogs up and gets blunted by grit in the bale. Much better is a reciprocating saw like an alligator saw. A strimmer is good for shaping the outside of a straw bale wall (if this is for straw bale building.)
What size big bales if there square they are in sections due to the nature of the baker stuffer and ram so cut strings take off as many sections ! What ever you do cutting the strings with a saw will cause them to come apart
Like the above says, just cut the strings with a penknife and u can take as many leafs as u need quite easily, just watch if a big square heston baler, have heard of a few farmers being knocked over/falling off things by the force they can spring out at (in a confined hay loft)
If big round bales, i roll them next to a pallet, flip it onto its end and just unwind the straw into a trailer or big tote bags etc, bit of a pITA to handle but means u can easily cover the bale to keep it watertight.
U can just roll them out but then u have to pick al the straw up thats scattered everywhere.
Ok thanks, so just cut string with knife and lift out sections. Bales are app 7' by 3'
Yes that's right just as above be carefull as they could be under quite a lot of tension depends how greasy the baler driver was :)
