  • Replies 33
Thanks everyone for the positive comments it took a lot of sweat and tears as I'm no fabricator but I'm really pleased with the outcome. If you have the time I'd recommend building your own partly because of cost but also you can change ideas as you go along to suit your needs. ImageUploadedByArbtalk1451840352.653706.jpg.e34a0b8c25cbc969e699a923222634d4.jpg
This is how It use to look.
i did mean to put did he have their Contact Details !
Depends where you live as they have loads of branches but here's the one I used
Thanks everyone for the positive comments it took a lot of sweat and tears as I'm no fabricator but I'm really pleased with the outcome. If you have the time I'd recommend building your own partly because of cost but also you can change ideas as you go along to suit your needs. [ATTACH]196431[/ATTACH]
If i made it would probably look like a turd, i know my limits :biggrin:
Whats cabstar like? they seem to offer a fair few engines that dont need ad blue.
I had a swb and it was fantastic had 2 transits before and would not have another. The pros definitely out weighed the cons. As 3 1/2 t tippers go I thought it was excellent. I put heavy duty springs on the back of mine so plod never knew what I was carrying.
More pictures of the build as stump squatter requested. ImageUploadedByArbtalk1451843702.723449.jpg.ffb2ea073f73f79637722a1b13d6b37b.jpg
So I striped the tipping frame down to this and built on from there.ImageUploadedByArbtalk1451843853.906336.jpg.792dc2179c4490e8e064a5acdda5865e.jpg
Added the box...ImageUploadedByArbtalk1451843896.556606.jpg.ec76b2e6974a0c028128dbdd0ffbb17d.jpg
Built the frame from 50mm x 100mm box and 25 x 40 strengtheners ImageUploadedByArbtalk1451844001.540255.jpg.c43f582d76db3a0da931199ae312ed17.jpg
Quick lick of paint
The side frame is made from 40 x 40 box and then added 40 x 5 flat bar to house the Ali panels as you can see a bit of in the last pic.ImageUploadedByArbtalk1451844237.290045.jpg.fba47e71ac683ab038dc3a843941c4d8.jpg
Started to cut and rivet the 200 x 25 hollow Ali panels with 4.8mm rivets with wide headsImageUploadedByArbtalk1451844381.791077.jpg.9a9c7dae5f3444c5519856dac37652b1.jpg
Headboard is made from corrugated floor planks as they handle the beating from the chip spraying better than the hollow planks
Doors are made from the hollow panels with caps on the ends
Steel roof but I would have preferred Ali but tried to keep cost down. Ow and roof and floor is made from 2mm steel sheet. Floor seam welded and roof riveted encase I decide to change it in the future.
More pictures of the build as stump squatter requested. [ATTACH]196434[/ATTACH]
So I striped the tipping frame down to this and built on from there.[ATTACH]196435[/ATTACH]
Added the box...[ATTACH]196436[/ATTACH]
Built the frame from 50mm x 100mm box and 25 x 40 strengtheners [ATTACH]196437[/ATTACH]
Quick lick of paint
[ATTACH]196438[/ATTACH][ATTACH]196439[/ATTACH]
The side frame is made from 40 x 40 box and then added 40 x 5 flat bar to house the Ali panels as you can see a bit of in the last pic.[ATTACH]196440[/ATTACH]
Started to cut and rivet the 200 x 25 hollow Ali panels with 4.8mm rivets with wide heads[ATTACH]196441[/ATTACH]
[ATTACH]196442[/ATTACH][ATTACH]196443[/ATTACH]
[ATTACH]196444[/ATTACH]
Good job! :thumbup1:
Very impressed!!
