9 hours ago, Ian C said:
Hi Andrew
Long time no hear!
out little dolly is still running, don't get much use mind, what ever happened to the new top handle mak/dolmar were bringing out?
Hello Ian
yes long time , they’ve come out and I’ve sold a couple of them haven’t heard from anyone so that’s good news , yeah I’ve been a bit laxadazical lately I should have posted some photos and information  , I will get one ordered up and maybe  do. A partial breakdown of the saw on here so everyone can see what it’s like
meanwhile I’ll put up some stock  photos
40cc class is covered by this Saw very good runner reliable easy to start  , runs on .325 050 narrow kerf or 3/8 lo-pro
Hi Andrew, the 420 is a cracking saw, punches well above its class. Loved mine when I had it. What was the cause of the problem with that one I part Ex'd you Andrew.
Hello Harvey thanks it is a fantastic Saw the 420 everyone likes them I’ve had some good feedback on the 420’s
your old 350 was a carb overhaul, new plug and fuel filter and tune up
Iam sorry I forgot too get back too you about the multitool Dolmar have made them NLA
but Iam always on the lookout for any that come up for sale
2 hours ago, Jamie Jones said:
I am intrigued as I have seen the Makita/Dalmar saws that comes with the metal boxes as to what it looks like inside and is there easy tools storage and securing features?
Yes there is a catch you can put a lock on there’s a slot in the end so you can leave your bar on t(e saw and stick it through there’s a small amount of padding in the box , also there’s a square compartment in the corner to keep any small items from getting damaged
sometimes Dolmar offer  certain models as a XXL package and you get the box and some other consumables included
21 hours ago, shavey said:
Hello Ian
What sort of price can you supply this for? Am I correct that it's about 30cc?
 Hello yes it’s 30.9cc and it’s the same as the makita ea-3100t
the price is £342+vat
On 09/11/2018 at 21:21, Dan Maynard said:
I would definitely be interested in a piston if the price isn't silly. It's been a good saw, although to be honest I use it less now I've got a 461. Taken down a few trees with it though, thought a pic would be nice.
@Dan Maynard I’ve got that piston for your 6000i if you still need it £17.89+vat
On 12/11/2018 at 17:56, DCS6800i said:
@shavey as promised
It has been chucking it down here today, so not much I could get on with outside so started on the 6800...
Everything went smoothly and it was a very straightforward build.
I have made 1 balls up though... I have a 115i stripped for spares also, and lifted the wrong oil pump worm drive!! It is pressed onto the crank, like a bearing, and I only realised it was wrong after I had pressed it on!! I need to make an adaptor for my pullers to get it back off, as they don't fit... but minus the oil pump and clutch she is rebuilt.
Took a bit of work to get her to fire up but the beast is alive!! The carb needs set properly, and obviously she needs finished before I can do that but I'm buzzing that she's running. (I hope the videos work - they were much longer but I had to cut them for the 7mb limit on here)
I managed too snag a OEM piston for 120Si / 6800i this week
