Am I being silly? 372 on a 16" bar?
TheHungrySquirrel
  • Replies 33
Big bore is 77cc's ish. Here is a big bore ported a bit hot on a 2165:
18", 8 pin, stock chain, in a maple that's been sitting a while.
If it is a BB kit, I would highly suggest using a meteor piston and caber rings. The kits piston I have seen had more tolerance than I care for.
Try putting that into some Aussie Hardwood like some iron bark... Good luck.
Sent from my iPhone using Tapatalk
Does such a thing as a 16" sugi bar exist for a 372?
Yes 16" is 60DL.
18" is 68 DL
But even with standard dogs the usable length is likely to be 2" less.
E.G with Standard Husky or Oregon bars on a 365 or 372
15" 56 DL usable 12.5"
17" 64 DL usable 15"
20" 72 DL usable 18"
24" 84 DL usable 22.5 "
Yes 16" is 60DL.
18" is 68 DL
Thank you sir, I'm currently on a 22 which is just a little to long I think. An 18 or 20 sugi bar may be the best for me I think.
Try putting anything in some Aussie Hardwood like some iron bark... Good luck.
FTFY
BTW, this is the guy I got those numbers from:
[ame]
[/ame]
wyk
Edited by wyk
