OK, figure this is a bit hit and hope due to the fact that most of the UK guys use smaller vehicles like Transits and Landies etc but anyone run Mitsubishi, Isuzu or Hino? Looking at around a 5 tonne pay load, older model (mid 90's) as I like the idea of a cast iron lump, easy maintenance and less money.
i run two mitsubishi trucks one a 6 ton fighter and one 4wd Canter
and one isuzu 1400 truck
The 2000 6 ton fighter is set up as a machinery carrying truck and as a chip truck as well as towing a 1800xl chipper
it is fairly economical to run and has 30000 km service intervals
it doesnt have much ground clearance though
the truck has done over 400000ks and is still going strong
Alot of the older Isuzu and mitsi trucks out here in North Aus seem to last a long time.There are plenty of trucks still running here that are over 25 years old.Mostly carting construction materials
I wouldnt think you could go far wrong with the Hino, isuzu, Fuso (mitzi) or Nissans, although with trucks it can be a crapshoot as rebuilding parts of them can be darn costly when they get bounced at COF time. 5 ton payload is a bit rarer though, most stuff abouts got a 2.5ish payload such as the elf250's etc.
Edited by Timbermcpherson
Timber, I have a couple on my hit list, one of which was an Isuzu forward juston. Great grunty truck but revving it's nuts off to do 90kph. 100 is pretty much no go and it really needed a sixth gear which is why the Nissan looks a better option at the moment. Smaller lump by about half a litre but 6 speed. I just can't get to drive it as its on the other island.
I run a Ford F350 superduty but unfortunately it's down rated here to 3.5t but still it has a 8ft bed that's 5ft wide and will tow all day long . Parts are not a problem and in 7 years I have had one coil pack that let me down .
Ste
Ste
Do you need a fuel bowser next to you to run it though!
To be honest No , if one drive's it sensibly it will return 15 mpg Towing has there is no need to rev its tits off like the inferior trucks out there but if you want to drive it like the Dukes of Hazard then boom 6mpg .
Ste
Edited by IVECOKID
Firstly its a truck, your not legally allowed to do more than 90.
Second, your complaining about being able to do 90 to a guy who owns a unimog
Third, your an arborist in the central north island, how much time are you going to loose a year only doing 80?
Fair point on the speed Timber. But at 90 it is ringing it out. 70-80 is probably top whack being somewhere approaching comfy. Central North Island I do quite a few kms and it's nice to be able to sit comfortably on 80 rather than pushing, if that makes sense. I can sympathise with you having a mog though. My mate had one with his business as did Treescape and 50-60 seemed like a comfortable speed for both without having your skeleton self destruct.
