  • Replies 149
With regards to logs jumping I know a fellow who had his front teeth knocked out using a HP eagle.
I like this machine from bgu - the gripper and bridge over the blade appear to potentially eliminate any possibility of logs kicking up at the operator.
Also any opinions on this style of saw, where you pull the blade through, rather then push the log on a cradle??
What HP is the tractor your running it off? our David brown is rated at 50hp off the pto when it came out the factory.
A quick clip running off my little Yanmar which is on the limit for this saw , well built and comes ready to go has its not a cheap bolt together job ,I find the working height ok even though i am 6ft .
I have demonstrated using it without holding the logs but really left hand should be holding and right hand pushing on handle .
Note I am cutting slow for demonstrating.
Only criticism I have is when cross cutting has the waste discharge chute can block up .
It has handles which I shown in clip and can easily moved about .
Ste
Ps Jim@ spectrum plant I drink Budweiser lol
Do they throw logs about that much?
On my balfour I would say you definitely have to hold the log as they do jump about a bit. A clenched fist pushing it down rather than hold though - an off round log can jump a bit and you can get your fingers whacked between the log and the unit ( I learnt the hard way!).
The holder looks good but I reckon you'd stop using after an hour.
That looks really efficient
It's generally operator error but when you are cutting for days on end it can happen. The finger whack is easy done.
Ive seen lots have the option of a conveyor, do you have 1 on yours? i know its more money but less work i suppose :confused1:
Don't have one but I can see how it would speed things up. I tend to have an ibc cage right next to me and just through them in.
