I used VMware to take images, then if I want to look at something I run it up on this mint 17.
Yes, thats a good way to run Windows, Ive used VMWare for a good few years & Virtual box also quite a good solution, prefer VM Ware though very good for testing server confgurations & software etc
When Windows borks its easy to restore from a snapshot
N
  • Replies 20
Got a new pc that had 8.1 on it so put 10 on straight away,its better that 8.1 but only drawback is the email, you cant create new folders for different emails so still use the old pc for this.
Thanks for the link. I followed the process, pc has now been configuring windows before restarting for 3 hours...
OK, not quite sure why its should take three hours to re-config after a simple removal of an update.
MS cause a lot of grief by thrusting its incarnation upon everyone
Is it OK now?
N
Hi should have happened on a re-boot
Not sure why its stopped, I know that procedure to work - seems just another bloody useless quirk of windows Im afraid.
Maybe F8 on startup & last known good? or hold Windows key & press R, type msconfig & click OK
N
Edited by NFG
