Woodworking chisels.... different types for what jobs?
Hi,
I'm looking to get some basic chisels for basic timber framing, green oak joints.... making mortice & tenons, scarf joints, etc.
There are lots of different types of chisel and I'm not sure what I need?.... is a 1" chisel a good starting chisel for timber framing joints, or maybe 1.5"?.... and is it best to have a bevel edged or straight?.... and what is a registered chisel?
Confused!! :001_huh:
cheers, steve
  • Replies 43
For framing bigger joints you want to aim for socket chisels so they take the abuse.
For most framing joints a 1", 1.5" and 2" will do all you need including marking joints and making them.
The best value new chisels are robert sorby ones, but there not a socket type, I have a few and they take the abuse. If you want to push the boat out and buy the very best then Barr make the best chisels.
A straight sided chisel will have more metal and be a little stronger but a bevel edge chisel having the corner knocked off will allow a little more clearance for some joints.
Also invest in a decent mallet for driving them with and some stones to keep them sharp.
Paul Sellars Utube
I went through a woodworking phase last year LOL
Cheers Hungry Squirrel :thumbup: ....socket chisels.... right, got that cheers. What kind of length should I get, or do they tend to be a similar length?
I was watching that Paul Sellars video last night..... those diamond stones look the biz.
cheers, steve
Axminster Tools and Machinery stock forged all steel wood chisels which I found very good and can be struck with a lump hammer. I bought the 30mm and 50mm straight chisels and wished I had also bought the 40mm cranked chisel. A 38mm 'normal' chisel I bought which was designed to be used with a steel hammer broke inside the handle after just a couple of large mortices.
Andrew
Framing chisels are longer than bench chisels to allow for the larger work.
Simplest set up for sharpening is 600/1200grit wet and dry. Stick some to a piece of mdf and use until it's knackered then glue on another sheet.
A lot cheaper than diamond stones and does just aswell
Ah, I see..... I won't be doing massive stuff so hopefully the bench chisels will get me by.
Good call on the sharpening.
cheers, steve
Yes - I work mine up through the grades 120, 320, 600, 1200 and for fine finishing 2400.
Alec
