Looking at getting Alaskan finally. But a bit stuck on what size to get . at the start I will be milling stuff around 15-30inchs as its a much more manageable timber size so would a larger 48inch mill be too cumbersome and awkward to work with on the smaller timber ?
I don't want to get to the stage in the future where I need to buy a second larger mill.. And have to buy twice
Thanks all
Arran
Get the biggest mate, you will lose 6" on bar length so a 48" should allow you to mill up to 42"
If you think you could need bigger I think they do a 56" one.
What saw are you looking to mill with?
880 would be ideal but a 660 will do you fine up to 30" logs.
Talk to RobD mate.
Pretty sure you'd only have to buy longer rails.
48" would indeed be a PITA for smaller stuff, but then so is having to hack down decent timber because you went too small!
20" with a 48" style set up is fine to use - plenty of stability there...
You can do smaller but it is a little cumbersome and inefficient - but not undoable.
It's a little like taking down a small tree with an over large chainsaw really!
:001_smile:
