  • Replies 32
When I fitted the piston and dropped the base gasket on I thought the gasket looked a bit too big , tried the bolts through and they went in ( didn't fit perfect ) so I dropped the cylinder on and put them through the gasket with the cylinder as high up as I could to make sure they were in right , fitted a new inlet boot , stuck a dual port exhaust on and it's been going like a train since . Had to use a blank on the decomp , or you could cut a hole in the top cover .
Theres not reallly that many bolts left,with all that gin you been drinking its only have the amount lol lol
Hahaha just noticed that a customer left me that 😂 I don't drink spirits 😜
Ordered a hyway kit😐 Base gasket air filter and some other bits for the saw, just need a bar and chain, hopefully it works out ok 👌
