  • Replies 29
someone on here had loads of potato boxes, if you go throught the search you should find it, or he will come along soon. stacking with boxes or pallets wrapped in fencing is great as long as you have a level yard.
Some initial investment but longlasting if you're not mechanical bulk handling: pallets in a line with concrete reinforcing mesh stapled to them as containing walls. You need crosswires too.
i use herris fencing, i put a layer of pallets along the ground, reinforce the corners and middle with stabs and just fill them up and cover them withan old bit of cylage plastic and tyres. your local farmer will have all this stuff going a begging, and the herris can be sourced pretty cheap. each bay holds about 50-60 dumpy bags believe it or not:thumbup1:
I use exactly the same system, unfortunately i'm such a luddite i have'nt worked out how to upload photos yet - 'spose getting a digital camera might be a first step:blushing:
  • 1 year later...
