Mine has never been gutless towing . It drags a Jensen A540 about no worries . I have removed the interals from the DPF , blanked off the EGR valve and fitted a larger bore stainless exhaust .
And mine will tow the trailer and a530t on so 1850-1900kg then a load of logs stuffed down the sides and the back full of logs (crew cab)
  • Replies 34
No its just a navara etc 54 plate so 2004.
tows great for me :D
Mine would tow more than 2.6 I was just wondering if they had changed the spec (down) it makes no difference as the most I tow I about 1t plus trailer weight.
Just seems odd that 190 hp now and still only 2.6 tow weight.
Yup that is poor, this can tow 3 tonne and i think are 130 hp?
What do people think to hilux so then? Seeing as most people are telling me the navara is crap and also a mechanic tells me to get a hilux.
They good once they get up into 150k miles or so?
I think a lot of it is luck I find the hilux un breakable but know a few people who had really bad experience with them. If you work a truck to death and it never gives a minutes trouble or leaks you tend to have a lot of confidence. Going to the expense of twin battery and 24 volt start would indicate they are built to a spec more that a price.
I have a 55 platenavara d40 166 thousand miles on it goes well not bad on fuel had a rodeo before that didn't like it was like been in a tractor slow and noisey and no room leg room compared with navara
