  • Replies 25
About £3500 plus VAT and UK delivery. That is on the basis that I can get 5 people to buy one of the basic mills. The haulage from Poland is around £2600 and it's obviously much more economical to put 5 mills on a wagon. Having seen or used a lot of small manual sawmills, there is a lot more steel in these than any other. It's standard with a 7.5kw three phase motor, but I can speak to them about a small petrol or diesel power plant if there is enough interest.
If you don't want to hire somebody like myself with 20 years of experience of milling to come and convert your timber, why don't you hire a mill from Ben Burgess in Norwich so you can evaluate whether a small band mill is the way to go over a chainsaw powered unit
Cheers. To be fair, it does look like a lot of mill for that money. Probably more mill than I'll ever need, and too static. Interesting though...
Like they say J - you can lead a horse to water but you can't make them drink.
I am in the very unfortunate position that I only have 1 phase. >1000 metres to a 3 phase location.
Digital converter, Diesel - what are your thoughts?:001_huh:
For that size of mill, diesel might be prohibitively expensive. Petrol would be a better bet.
Sadly, with an electric mill it's not just a simple case of switching the electric motor for a petrol one - all the motors for head movement, hydrualics etc are electric and 380v. They need to do it to crack into the UK market, but it's a significant undertaking.
So its a phase converter or nothing. Do you know the total Kw requirement for the 600 and yours?
3rd option - used diesel generator. As you know they are available if tricky to source.
I have a 50kva generator. It was going to be a new one, but a delivery delay meant I cancelled it and bought a very low hours used genset.
There are advantages with electric - it's extremely quiet and the torque is very impressive. The little mill has a 7.5kw main motor, which would need a 12-15kva genset (a guess).
Ah, sounds promising. Appears that there are plenty of Diesel 3 phase around 25-30 kva around 5k - so that's ideal.
So looking like genset 5K +vat
Mill 15K +vat
Carriage to uk and in UK to me?
Import duty etc ?
Installation 2K
What is carriage likely to be on your mill?
Do these figures appear consistent with reality ?
Thanks
That's maybe a bit high on the genset cost. Mine wasn't quite that and it's 50kva.
Mill at £15k get's you fully hydraulic and wide cutting head, as well as some extra hydraulics/tools.
Dedicated transport would be required for a mill that size (might squeeze something else on) and would be about £2500. Was about £2000, but migrant issues in Calais build cost.
Installation cost was a tough higher for me as I put a £2800 concrete pad in.
You are very close to reality though. Pays off quickly enough though - in the next month I have the value of the mill and generator in orders waiting to be cut. Mostly softwood with a lorry load of elm thrown in for good measure.
Mill 15K +vat
Import duty etc ?
Installation 2K
Thanks
Read more
