Right kids.....everyone seems to have different opinions.....I have a braked tipping trailer....could I...if a tow ball was suitably attached to the trailer, drag my braked chipper behind the trailer...loaded or unloaded?!!
Yup
AS far as I an remember only showmans guild and farmers are allowed to tow anything behind a trailer. They did look at proper road trains a few years ago but decided against it
Whilst the advice give is correct its not the full picture.
If the first trailer is taking some of the load of the second trailer & the first is specificaly made to do so it is allowed. This was really for turntable type trailers & recovery vehicles.
A heavy motor car or a motor car not
described in item 1, 3 or 4 can tow:- 2 trailers if one of them is a towing implement and part of
the other is secured to and either rests on or is suspended
from that implement
1 trailer in any other case
Its all in regulation 83 of the Road
Vehicles (Construction and Use) Regulations 1986 (C&U), as amended.
4. Towing implements.
A ‘heavy motor car’ or ‘motor car’ (e.g. the motor vehicle forming part of an articulated vehicle) may only
draw one trailer. The exception to this rule is that such a vehicle may draw two trailers in situations where
one of the trailers is a towing implement and part of the other is secured to and rests on or is suspended from
that implement.
A towing implement is defined in regulation 3 (of C&U) as: “a device on wheels designed for the purpose of
enabling a motor vehicle to draw another vehicle by the attachment of that device to that other vehicle in
such a manner that part of that other vehicle is secured to and either rests on or is suspended from the
device and some but not all of the wheels on which that other vehicle normally runs are raised off the
ground.”
Towing implements are a device constructed and used for the special purpose of vehicle recovery. In
recognition of this, regulation 4(4), item 7 in the table, and regulation 4(5) of C&U provide exceptions for such
devices from the full requirements of C&U. These exceptions allow the device to be constructed and used in
such a way that enables the recovery of broken down vehicles.
So in your case no you cant tow the chipper behind the trailer.
Edited by Justme
