Id say yes, but I already had the loader and the grinder was only 3.5k. id say it was as good as any of the smaller grinders, except for access issues naturally, but not as good as the bigger bandits, Carltons etc. I don't do enough stumps to justify spending any more money, and for that money you couldn't even buy a little 13hp grinder. Visibility is great, you can see everything you are grinding. its only 23hp which I feel is a little under powered now ive got used to it, but like I say perfect for my business.
On ‎11‎/‎11‎/‎2019 at 17:18, woody paul said:
Stump grinders go blunt when you hit dirt, and aren't a lot of grinders on tracks.
Yes they are, but if you know what you are doing, you do NOT grind a stump from the top!
You start at the side so that you are effectively planning along the grain and not cutting across it.9_9
