hop handle 540xp
treeandy
If you go for 540 make sure it has the beefed up grey bottom plate with the stronger spring mount and the " barrel " shaped spring and the new tank with the limiter tether .
Limiter tether that hols the tank to the body? Is it a bolt on new part or a complete redesign?
Brand new tank with spigot for limiter wire , brand new bottom plate with beefed up spring mount and new barrel shaped stronger spring .
Finally, you've spilt the beans!!
Mines still in one piece and I love it, but should it ever break, are these parts available for all 540's ??
