Roughing gouge
mickdundee
I was told the tang on a roughing gouge is not as long or as strong as the one on a bowl gouge. So stick to a bowl gouge on bowls and keep it really sharp.
That is the advice given to me by my instructor at turning class
i went to a demo years ago at toolpost and when i said that i used the roughing gouge to do the outside of bowls he looked at me like i'd just confessed to murdering his kids...
i rarely use it for that purpose these days as i use a 2" roughing gouge and that really is too big for doing the outside of a bowl.
the tang is not as chunky as a round section bowl gouge so that reason is correct.
  • 3 weeks later...
I use a 5/8 bowl gouge from start to finish, roughing shaping and sheer scraping, then finish off with 320 grit. Also I never use a chuck on bowls. I start between centers to find a balance point, finish the outside then use a glue block for the hollowing. No need to reverse again to finish turn the spigot or recess and rarely need more that a cursory sanding. It goes against most of the norms, but works for me.
S.
