Picked up a couple of large ones yesterday off a bloke down the pub , what's the best to do with this ? The faller wants a bowl in return for them can it be turned green or would it be better left too dry then turned.
Thanks mat
Hate to think of the lovely stem they were butchered off of.
Don't work your self up j they came off a tiny wolf stem , the guy has some mill able stuff if you want I'll take pics and send them too you, it's going at £45 a tonne but there is not quite an arctic load but tbh I don't know as I've not seen it.
i think you should use a bowl saver on those to get the best out of them other wise you only get two bowls.
i think i can get 8 out of those.
Bowl saver ? I'm thinking you can get a few off them for sure.would you put them at the back of the shed for a couple of years though? I've only turned stuff that I've salvaged and left once it's dried if I've wanted to keep it.
I am glad! It makes you cry the stems that get ringed up/hacked up because of people sadly not being clued up. I'm not saying it's anyone's fault, only that I'd urge any cutter to post a couple of photos of a stem that they think is possibly unusual. You might be surprised of it's value.
Anyway, I'm OK for elm at the moment. Looking at three loads next Monday in Morayshire :D
I would of rather he put the whole thing on one of the fire wood loads we just brought off him.. Would of rather of seen it on my mill! Luckily I did find what I think is the dead top off that tree and mill it when we moved one of the loads.
a bowlsaver will give you a nest of bowls rather than one big one.
personally i would use the bowlsaver to get 3-4 roughed out bowls from each burr then seal the grain and leave for 6 months to a years for it to dry.
Woodcut Bowlsaver Bowl Coring System - Woodturning Lathe Accessories - Woodturning Lathes - Woodturning - Woodturning & Crafts | Axminster Tools & Machinery
[ame]
[/ame]
Great thanks , I'll look in to one of these I don't think the guy was in a rush but I've only just started turning stuff that I've been saving as its dry now.
