The whole depth thing is a bit of a grey area, mostly when grinding you move forward on the grindings thereby lifting the machine. If you remove the excess and do another run through you're going lower anyway.
Swing is more important than a couple of inches of perceived depth imo.
Spec sheet for the wheeled 2550 only shows a depth of 34 cms which is a couple of inches less than required.
Both models are 38cms, if you have turf friendly tyres it's 39cms.
We offer the Bandit 2550xp as a 4WD or tracked machine, tracked machine weighs 1.1 Tonnes, cuts to 40cm, 45hp turbo, hydraulic drive, radio remote, hyd dozer blade.
The wheeled model is basically the same but 4WD, dual wheels & cuts to 39cms.
Buy it open spaceman!!
It's not for me, I sidestepped proper work 6 years ago, but when I worked for him I vowed not to use the Dosko again, I had the strength but not the stamina. He quotes to get through the "crown" of the root to soil beneath, this often means excavating a ramp on larger stumps.
The Bandit looks ok in a rugged american sort of way but what's the point in a brochure quoting one depth and the salesman claiming more?
I'll have to see what's affordable.
