Securing a speed line
SPC Trees
Depends on the size of the lumps being zipped down. A groundy, a pile of logs, the chipper, a tree. As long as they are suitable for purpose. You would be amazed how good a pile of logs is as an anchor though.
Fairly good idea, saves damaging the customers lawn too. I would get a groundy to just hold it for lighter branches. I'm talking about the heavier chunks...
  • 1 month later...
Tow hitch, couple of groundies or a metal spike hammered into the ground at a slight angle. I definitely wouldn't risk tying to a concrete post, they're very prone to snapping. There is a way of doubling the rope back on itself and securing/tensioning it with a prussic so that when the piece reaches it, the contact with the prussic gently collapses the system and the load lands safely in a pre-determined spot rather than crashing into the vehicle/chipper/groundie etc..
On this particular job I used 6-7 road pins and drove them a long way into the ground into the ground. Worked well with the limbs, but the timber began to bend them so we changed to snatch and pull line.
Obviously in this scenario we also used a control line in case the makeshift ground anchor were to fail.
Edited by TKO
