We have had loads of of little beech seedling come up in our fields this spring. They are about 2-3" high but will get eaten when the sheep go back in in the field. Will they survive being transplanted now and if yes what's the best way to dig them out?
Thanks :001_smile:
Beau
Suppose I did ask for that :laugh1:
Ok the ground is as hard as nails so don't want to waste my time if they are all going to die. Not sure how much you need to dig out to not disturb any roots. Wondered about using a post hole digger but sort of in reverse to get them out.
Dig out a couple of buckets/wheel barrow of soil from edge of field, level it off in the buckets/barrow and moisten. Pour water over the treelet and wait for the water to percolate down through the roots and soften the surrounding soil. Do say five at a time. Did out around and down 6"x6" but before temporarily replanting, tease out the entire root system of the first. This will give an idea of the future hole-soil to be dug out with each seedling. No point giving each 6x6" if you only need 4x2".
Generally, loamy or sandy soils are preferable for growing beech trees. Silty soils that are moist while also draining efficiently are prime locations. Chalky soils are a common example of prime growing conditions, but many other types of soil may also be suitable.
When you're done lifting, repot each seedling in a separate pot, big enough not to bend the roots into a ball. Mix the field soil with some bought ericaceous soil 60-40% and add a little grit/sand for added drainage.
Don't bother putting them in a greenhouse, as this will dry them out. Beech like damp but well drained soil. Which is why one often finds them on hillsides. If they came from a shaded area, then place them in a shaded area. If they came from a full sun area, then place them in full sun. They're hardy and will only need watering if there's a dry spell. It's worth bearing in mind, that while in pots, they'll be more susceptible to frosts and premature drying. So keep the soil moist but not dry nor laden.
You've got a farm, now you've got and arboretum. Plant in final position when big enough, (whip size). Happy gardening.
Edited by TGB
For the replanting how close can we plant them and do they need pots? Also we have a large raised bed that's unused so would that be suitable?
Thanks
