200t prob
philip2011
So after much headache of suppliers sending wrong springs went to beever plant and ordered them in fitted last night and still the same so back to the drawing board could it be the carb possibly ??? Cheers people this one has got me stumped big time and have knowticed if you hold it on tick over with chain brake on and move it up and down the engine ever so slightly revs up thanks in advance Phil
On one of my posts I said: -
"If the chain doesn't creep forward, it sounds like you may have an air leak in the clutch side seal - I notice when doing leak down tests that these saws can leak if the crank is pushed to ones side - just down to the needle crank bearings and hardened seals! "
I would say that your chain brake is putting some sideways force on your crankshaft and that the seal on this side has worn or gone hard so is leaking air when the brake is on - fit a new seal!
