Hiya, does anyone have the number of the bearing for a tw150 please? When I did mine ages ago and I had the boxes I googled the numbers and found them at the normal bearing shops, which I have one of just down the road.
If you can get them off in normal working hours your bearing factor will measure them and give you a match. Alternatively a vernier is cheap as chips so you could measure your self. Also there should be numbers on the bearing.
Edited by cornish wood burner
The bearing shop is near my house in sheffield but I'll be stripping it down in lincs at a friends so won't be able to measure. Thanks for the reply though.
Nice one Kev, just had a google of the numbers and it looks about right. I will double check with the timber wolf help line first before I order. Cheers chaps
make sure they are c3 spec bearings
It's interesting what it says about the c3 type on the net. It seems they are good for heat and speed but not suited for their intended use?
"What are C3 bearings?
C3 bearings are bearings that have an additional internal radial clearance to cope with high speed environments where excess heat is generated.
They are not suited to environments where critical alignment is required from the onset e.g. Where blades and cutters are set up to each other."
