As you can see, there is a fuse loose here!
I'm assuming one of these missing fuses controls the cab lights in my Hilux single cab (1998), but as the fuse box cover (and fuse diagram) in the driveside footwell is missing I can only hope! :confused1
I need a favour :biggrin:
Could I ask one of you kind fellow hilux drivers, that have a similar setup please post a pic of their fuse diagram so i know waht fuses slot into them there holes.
Here's hoping!:thumbup:
Thanks for the advice and for having a look Treeswinger, maybe thats what it is! Prehaps I'll swap a few round and see if I can identify a blown one!
I tried having a look at the images on google before Yournamehere, but couldn't find a fuse board similar to mine. Thanks for the headsup/cough though ;-)
You can identify a blown one by looking at it from the side, if the wire is broken where it goes thin it's blown. Look where the number is printed on it.
[ATTACH]179665[/ATTACH]
Are you on hpoc, loads of info and helpful members
Mine's older unfortunately
Thanks for the help chaps! The fuses turned out to be of so, will have a look on that website mentioned to see if I can get to the bottom of it.
Hiluxstihl, I'm not sure if its a Mk3, 4 or 5 tbh :confused1:. Maybe you could tell me, it's the yellow one!?
