We are currently looking into developing a universal stress control unit! We currently recondition many older units for customers but as addition now are looking to offer a new cost effective replacement made in the UK !
We are exploring the options of a box which can be ordered to your own required spec eg digital display or just led light indication , external speed setting buttons to allow you to alter/set stress control to your own preference
We could also add a auto engine shut down option eg engine over heats or low on oil.
We would be happy to hear your comments on what you would your control box to do, look like/controls ect
Our control box could also be fitted to stump grinder of other machinery which needs load control
Not sure it's that easy unless you could activate/deactivate functions, ours is £292 so I guess it would have to be cheaper than that. Some machines have engine shutdowns already fitted on a separate system & some don't, some have feed roller reverse & some don't & I assume you could only sell them outside the warranty period.
It wouldn't need one if its still under warranty !!
We are looking at a system that you would be able to order it to spec'/features you would want, like an extra options list !
The box would be standard -
Stop/start stress control with easy external button setting so you can adjust to your own preference
Then additional features could be added like
Auto reverse
Digital display
High Temp shut down
Low oil pressure shut down
If you tell use what features you would like it to have and we will work out a way to make it possible!
We would also offer a repair service so should it go wrong later on it wouldn't mean forking out for another new replacement!
We are also looking at other features which aren't offered on any other systems ( so hence can't disclose details at this stage!)
Edited by WeFixIt
