Buying a unimog
Davewoodchopper
  • Replies 51
if a mog is very shiny, just been resprayed and smells like halfords then stay away from it. i have run mogs for 7 years now, go for it..
I wonder who your talking about:sneaky2:
Recently had the tank on one of unimogs i drive cleaned out was about 1lb of sand in it we assume! from the sandblasting of the chassis:thumbdown:
google acprice, he will come up first, some mogs are left hand drive mark. i couldnt put a nut in a monkeys mouth but i have a mog, if they break down then just get someone to fix it, thats what i do..if you plan on buying a mog, then plan to do a lot more work with it, but with bigger turnover comes bigger repair bills. i am looking at another mog just now in the region of 50k, but you can spend as little as 5 k for a little play about. it depends what it has on it, you can pick up a flat bed x army mog for under 10k, but one with all the agg stuff on it and chip body, depending on which model, under 20k is going to be a bit rough i reckon.
I've had mogs for 12 yrs, The 1000 in the pic was bought through Frank Atkinson. 3 had just come in from Germany (ex council) and were at Hull docks.I went across to Hull, tried all 3 and choose this one.£10500, full ag spec 24 speed with a creeper box. Replaced one wheel bearing in all that time and it's now needing the brakes sorting and a general spruce up. Been looking at the cost of swapping and it's looking like I will need to put up about £15k and my mog to get anything decent.
