Finding/curing oil leak on Honda engine
scbk
Hi folks, got a Honda GX340 which has developed a small oil leak.
Just the odd drip I think but the machine can be in use for a few hours at a time on the same spot so it can leave a mark
Even after cleaning and running it again it's hard to see where it's coming from as it's well splattered over the engine.
Has anyone got any tips or suggestions of what it could be or where best to start?
Thanks
Could also be worth a look around the rocker cover to as they use a rubber gasket which can deteriorate.
Its a bit hard to advise a start point without a few more clues tho as generally Hondas tend to be pretty good. Any particular side/area its concentrated in?
If its splattered is it around the exhaust area? When the rings go they can throw some out the exhaust.
Edited by wisecobandit
If the oil is splattered it would indicate that it is being thrown, so I would guess the crank seal, then being thrown by the pulley or flywheel.
Other leaks should just run down from their origin, just spreading along horizontal lips etc.
Get the motor clean and degreased with some Jizer, then run it and watch.
Thanks :001_smile:
I did change the rocker cover gasket a couple months ago as it seemed like an easy place to start! - the old gasket had a small nick in it but it obviously wasn't that.
It looks like it could be somewhere in behind the exhaust or fuel tank as that looks like the highest point that is damp.
I will see if I can investigate further later on in the week.
It's sods law that if I take it apart I will need it the next day!
  • 3 weeks later...
Got the flywheel off with a homemade puller (bit of steel)
I assume it's the crankshaft seal, plenty of muck splattered round behind the flywheel?
How do you change the crank seal, is it possible to do it without splitting the engine open?
