  • Replies 117
Bit of redline diesel treatment every now and then will be good for it then.
I use a dash every fill up .
whas it do Stubbers, is it a detergent type stuff that helps clean up carbon deposits?
I will read the bottle and get back to you ....or Google it ....:001_smile:
OK from the label ....Better combustion
system lube
reduced detonation
detergents to clean injectors
O ring and seal lube
reduced ring friction
ceatane booster and makes you walk on the water and fly in the air .
Edited by Stubby
system lube
reduced detonation
Thank you Stubby. Can I apply some to my wrists and neck line ala Brut 33 or Old Spice?
Yes you can do that . Let me know the results . :biggrin:
