Morning all,
Thinking about purchasing a zigzag, Iv seen a lot of threads rating them. Are there any of you who use it on every climb you conduct or do you just use it for the big stuff? I'd like to just use the one system on everything if possible.....
  • Replies 24
Use mine for everything, not used anything else for a couple of years, mine cracked months ago, but never got any worse, I'll probably change it at one of the shows, I don't want to be without it.
Use mine on most climbs. I'll sometimes switch to a hitch climber if I'm working close to the stem. ( I find that the zigzag will "bend" against itself )
