  • Replies 42
much more energy per ton than chip,
That must be wrong?
All wood of the same type at the same % moisture will have the same energy in it no matter if its in logs, chip, pellet or matches. You cant add energy by changing its form. In fact if you take into account the processing power used to make the pellets (hammer mill & pelletiser) the NET energy will be less not more.
Justme
Can these machines take planed soft wood off cuts. can man made board be used like sterling board chipboard or ply I would imagine the glue causes a problem when burnt.
The only thing is logs pretty much sell for £160-00 a tonne (properly dry logs that is)...
How much did it cost your mate to get a pellet making machine? It seems there are grants around towards these things.
And I don't suppose you can pelletise your chip mulch (after drying)... This sort of thing could be the future but I suppose like anything else you really want to have the market there first before buying all the gear in.
he got a 50% grant towards it, he did say someone rang up saying they didnt need the bark taken off and that they wanted 50 tonne a month, he is considering getting a machine that processes, obvoiusly it cant cut the stock properly but my idea was to go in and just fell the chestnut then let the machine do its job
my thort is that the customer is happy if its chesnut coppice and that nowadays you can get the coppice for zero penneys or in fact they sometimes pay you to maintain there woodlands, so if these chestnut woodlands are not being coppiced for rails and posts, its a market for any woodman to consider.
there are grants out there, you just need to know who to contact
Just from doing a bit of research after reading your thread I'm now thinking it could be the way forward (as part of your business anyway!!). Now the whole pellet thing is in it's infancy but in 3 to 5 years it could be much more widespread.
It seems you can make fuel pellets from anything be it straw, waste grass and the like as long as you have the means to dry it. What I'm thinking is if you had the right pellet making machine for your general tree waste.
Would take a bit of time and research but if you can make burnable pellets out of grass then you should be able to nake them out of chip mulch. I suppose you'd want to speak to people selling the boilers to see who has got them installed and what fuel they're using.
It's not good having a mountain of pellet and no where for it all to go! Can you divulge where your mate got his grant from? I know DEFRA seem to want to get the whole pellet fuel going.
Contact DRAX they will buy as much pellet off you as you can produce. Yes you can make pellet off of chip.
Ed is the expert on this but he's away untill Saturday night.
Buzz can u ask Ed to join on this thread if you can as I'd like to find more out about these pellet making watsits!
ive got an email with the application in it that my m8 sent me so i can forward it on to ya, wots ya email address
