  • Replies 21
We re sharpen in situ with an angle grinder with diamond wheel.
Diamond coated vanity blade / Abtec4Abrasives
And I have just found, and used, these guys for grinder teeth at a very reasonable rate. Really nice to deal with, and very efficient.
Stump Grinder | Stump Cutter |
Sharpen often, and replace teeth when they get too worn down(25% of face of carbide tip), this really effects performance.
Make sure the leading edge/tungsten tip is proud (and sharp!) of the holder behind
Just to add: we have a 1000w power convertor in the truck (if there is no client in) and a 50m extension lead to sharpen on site
Edited by redmoosefaction
There a lot cheaper for the teeth! Do you have to enquire before you order??
I ended up getting 60 teeth (the vermeer pro teeth) and discount was really good, especially when you compare them to other peoples prices!
Mention that you got the number from Arbtalk, I said I would spread the word for him.
