A daft question maybe but are sprockets interchangeable between 066 and ms360?
Rims are, as long as the 360 has a standard (large) 7-spline drum (not all of them do).
The question is not daft at all!
Edited by SawTroll
Our 361 has a spur sprocket, so that one won't be. The later ones had 3/8 rim sprockets, so as long as you 66 is the same guage it should be fine.
Easier to change them on Stihl than Husqy, which involves a hammer and swearing.
Unless you have a 372 then its just a circlip :001_smile:
The gauge doesn't matter, but the pitch does of course! :wink:
Stihl is same gauge, .068, from the 261 to the 880.
