Any idea how much a cubic meter of composted woodchip weighs? I am working out a quote for delivering 150tons and would like to work out how many cubic meters that might be.
Β
Thanks for your help
Β
Β
depends if its wet or dry.....
big difference:scared1:
cubic meter weighs around 400kgs but as said is it wet or dry
Edited by log supplier
Well its all stored outside so its not dry stuff. Mostly semi composted.
Β
Its suprising how dry parts of the inside of a chip pile can be which will drop your weight a fair bit. Cant you do it by the Cube?
Β
No, The client needs 150ton for some sort of reedbed/water cleaning project. Cant get an artic into their site so I need to work out how many cube it is.
Β
A tonne at what moisture content ??
Β
You will have to assume a cubic metre is a tonne, otherwise the only way is to weigh each and every load.
Β
Its kind of asking how much a glass of water weighs :001_smile:
I once had an outdoor pile of chip. I filled a rolonoff skip and the chip was warm and dry on the inside. I think it was a 40cube bin and it was weighed with 13tons in it. If that's any help.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
